tminer
Not quite normal
- May 25, 2001
Only ran 2-3 years back around 2003 and switched to front mount. Shroud has peeling paint. Only have passenger side bracket (uses stock driver side bracket) and water pump bolt/spacer. You'll need 3 5/16x18 1" mounting bolts with lock washers, 12 1/4" hex head self tapping sheet metal screws and a replacement for 3/4" hex adapter. It screwed onto the 8Mx1.25 engine stud that stock ic used and a 4th 5/16x18 bolt attached the bracket. I can't give exact instructions as my TA oil pump is in that area, but basically just need an 8Mx1.25 (3/4"?) all thread spacer and bolt/lock washer.
$450 plus shipping or best reasonable offer.
