hemi8
Goin Sideways
- Jun 6, 2001
Casper's thumbwheel chip Version 4. This comes complete with everything, chip, spec sheet, cable which goes from chip to the dash mounted thumbwheel. The chip is set-up for my combination but Casper's will re-tune it for your combo if needed for minimal cost. You can also send this chip out to whomever burns your chips and place all differant settings on 8 positions.
The combo it is set-up for is:
TE-63 turbo
50 lb injectors
9 in convertor
ported aluminum heads
small 212 roller cam
front-mount
Position 0 is an anti-theft no-start setting.
Position 1 is a emissions chip (worked for Virginia emissions test for the past 10 years).
As you go up in numbers the timing and octane requirements go up.
$175.00 shipped to lower 48
Mike
86 GN
TE-63 turbo
50 lb injectors
9 in convertor
front-mount
Mike
86 GN
