- May 26, 2001
I have some good parts that I recently removed, for sale.
Precision TE-44 turbo. Has approximately 2000 miles on it since it was installed by the previous owner in 2016. E cover (3" inlet, 2" discharge), with Precision 3-bolt .63 A/R turbine housing, studs with nuts and lock washers on oil drain, nuts on the 3 header studs. -4an fitting installed on oil feed, but will include a new brass fitting for the stock OE oil feed line. Compressor cover has a hex keyed allen plug where the air fitting would normally be. New brass hose barb fitting included. Bolts and nuts for the heat shield bracket. Turbo also comes with a Heavy Duty wastegate actuator, a 2" to 3" black silicone reducer hose with t-bolt clamps and an RJC boost controller. This turbo is ready to bolt on and performed flawlessly when I took it off last weekend. I upgraded to a larger turbo was the reason for the swap. SOLD
Set of six, Delphi 50# injectors, 4000 miles on them. Ran great with decent gas mileage when removed last weekend. SOLD shipped in the lower 48.
3" polished aluminum MAF pipe with black hoses and clamps. SOLD
Caspers Electronics Ultrachip for 50# injectors and alky. This is a 8 position, adjustable chip from Caspers. It worked very well with this combo. (TE-44, FM IC, stock engine with ported iron heads, 3" downpipe, dual 2.5" exhaust) Setting 0 is the anti-theft mode, car will not start. I upgraded to larger injectors and chip is the reason for selling. SOLD shipped in the lower 48.
MSD 8.5mm red spark plug wire set with separators. Like new condition. $70.00 shipped in the lower 48.
3" mild steel dump pipe. $50.00 shipped in the lower 48.
PayPal preferred and sent as Friends and Family to avoid any fees.
-Patrick-
*Note: Price change on the injectors.*
-Patrick-
