BuickMike231
60% of the time, it works every time.
- Feb 21, 2007
Hey guys, I am getting ready to replace my cat. converter hanger as the rubber is completely shot on mine. My question to you is how exactly does the old one come off? I see there are the two bolts that connect to the tranny crossmember, and it's kind of sandwiched in there. If I undo those two bolts, can the flat part of the cat hanger slide out or is it more complicated than that? I was going to buy the replacment that has the bolt hook, the rubber isolater, and the flat piece that mounts to the cross member. I just wanted to make sure before I start removing stuff that I have the right idea. If it's more involved than the two bolts, what else needs to be removed? Thanks in advance!
