Catalytic converter to tailpipe bolt size????
witchdoctor813
About to change out converter for test pipe with dump. Anyone happen to know the size of the four bolts needed on the backside going to tailpipes??
AIRC, the oem converter had studs in it. When removing it, you end up w/ holes in both sides. You can use 3/8" bolts/nuts. I'd use all steel self locking nuts.
The stock cat has 10mm studs, and the nuts are a 15mm hex.
Like what Chuck said, you can use 3/8" bolts and nuts for the dump pipe.
My car had bolts (18mm) on it when I got it, but I removed the converter (what was left of it) and installed a test tube like the OP is going to do.
