- Feb 14, 2002
PS.... I'm not saying don't use a catch can, just bringing to light the reasons why they look the way they do.
SignUp Now!How is this system plumbed, that it's getting that much oil?
Is the engine "looser than a hookers Panties"??![]()
I guess to me it doesn't make a lot of sense the way they have that can designed. Basically, why does it have a breather on it? The breathers should be on the engine where they can ventilate the crankcase at WOT, and the PCV system should be closed. With a breather on the catch can, and the can installed inline in the PCV circuit, then the PCV will pull fresh outside air through that breather and not pull the crankcase vapors.
If they intend to vent the crankcase entirely through the breather on that can, then the fittings are way too small. The engine will build crankcase pressure at WOT due to excessive crankcase ventilation restriction. This will make the gaskets leak and push the dipstick out.
If the engine has some breathers on it, and the can is closed up tight, then it would make sense to me.
If you get one I would use it with some breathers still installed on the engine to handle the WOT blow by. Just because the hose and barbs are too small to prevent crankcase pressure from building at WOT
Here's another choice .
I've got 2 of these catch cans on my car.
One for the PCV system, routed back into the plenum (with a check valve in line) , the other venting both valve covers, then routed back into the MAF pipe (pre turbo).
Works well.
http://www.accmachtech.com/catchcans.asp
Mine is plumbed the same way. I always get a lot of oil in the can going to the PCV can and hardly anything going to the valve breather can. Must be the velocity explained in post #20 by BEATAV8.Here's another choice .
Works well.
Nice looking piece!
Are you using a stock pcv?
What are you using for the check valve?
Hi Chuck
I'm using the plastic AutoZone 1162 PCV Valve, think it's labeled "LuberFiner"
Just be sure to check it to make sure if holds pressure in one direction and doesn't leak. Blow through it and be certain it's a positive seal before you leave the store. (I've found a few of them did not).
Here's a picture.
For the check valve, go with US Plastics 3/8" Kynar check valve.
Part # 64175
http://www.usplastic.com/catalog/item.aspx?sku=64175
44 will be OK (not great ) if you can get it with .63 garret housing
What other choices are there, that may be better??
