All ARP PARTS LISTED ARE NEW FROM ARP< NOT CHINA KNOCK OFFS
NEW - NEVER INSTALLED PART NUMBER CCA-772-12 Titanium retainers - $155.00 shipped - PP OK cover fee's
Brand: COMP Cams
Manufacturer's Part Number: 772-12
Part Type: Valve Spring Retainers
Product Line: COMP Cams Titanium Valve Spring Retainers
Summit Racing Part Number: CCA-772-12
UPC: 036584028550
Outside Diameter of Outer Spring (in): 1.055 in.
Retainer Material: Titanium
Lock Style: 7 degree
Valve Spring Style: Standard
Retainer Style: Standard
Number of Springs Per Valve: Single
Inside Diameter of Inner Spring (in): 0.640 in.
Locks Included: No
Quantity: Sold as a set of 12.
Notes: Designed for use with CCA-26915 or CCA-26918 valve springs on LS1 engines.
If you're a serious racer, you'd better be sure that you're using strong valve spring retainers, such as these COMP Cams titanium retainers. They're stronger and lighter than steel, which means that you'll gain speed and power. They use COMP Cams' Super Lock technology and are designed for 10 degree valve stem locks. These retainers work best with COMP Cams' valve locks and optional lash caps, and you can be sure that they won't split at high rpm, tearing up your engine.
Pics of the retainers:
![](/proxy.php?image=http%3A%2F%2Fi5.photobucket.com%2Falbums%2Fy171%2Fsnakekillenws6%2FIMG_1602_zpssgm9k4dz.jpg&hash=d7df7ef101d75c02e41ad67dd9b05227)
![](/proxy.php?image=http%3A%2F%2Fi5.photobucket.com%2Falbums%2Fy171%2Fsnakekillenws6%2FIMG_1601_zpsqyoag6qe.jpg&hash=9eb3648de589669d23f183ed8599f84d)
NEW Never opened - ARP-123-5401 $55.00 shipped PP-OK you cover fees
Brand: ARP
Manufacturer's Part Number: 123-5401
Part Type: Main Cap Fasteners
Product Line: ARP Main Stud Kits
Summit Racing Part Number: ARP-123-5401
UPC: 672036001070
Main Bolt Style: 2-bolt
Fastener Style: Stud
Fastener Nut Style: Standard hex
Works with Windage Tray: No
Fastener Yield Strength (psi): 200,000 psi
Nuts Included: Yes
Washers Included: Yes
Quantity: Sold as a kit.
These ARP main studs are made from 8740 chromoly steel and have a 190,000 psi tensile-strength rating. They are precision centerless-ground and thread-rolled to Mil-S-8879 specs, with a black oxide finish for corrosion resistance. The kits come complete with hardened washers and high-strength hex nuts.
![](/proxy.php?image=http%3A%2F%2Fi5.photobucket.com%2Falbums%2Fy171%2Fsnakekillenws6%2FIMG_1597_zpsegfyjlhh.jpg&hash=9f0a1c6c28e57a39bea1914cb6ed48fc)
![](/proxy.php?image=http%3A%2F%2Fi5.photobucket.com%2Falbums%2Fy171%2Fsnakekillenws6%2FIMG_1598_zpsppr3qfll.jpg&hash=9d31d565c3d68022bf3e40aafed33398)
New Never opened - ARP-4003 Head stud kit $85.00 shipped - PP-OK you cover fees
Brand: ARP
Manufacturer's Part Number: 123-4003
Part Type: Cylinder Head Fasteners
Product Line: ARP Pro Series Cylinder Head Stud Kits
Summit Racing Part Number: ARP-123-4003
UPC: 672036001032
Undercut Stud: No
Head Style: Hex
Fastener Material: 8740 chromoly
Fastener Finish: Black oxide
Cut to Fit: No
Notes: Fits Grand National and T-type cars only.
Pro series cylinder head studs from ARP are cold-forged to ensure molecular integrity. They are heat-treated prior to thread rolling and machining and are rated at a whopping 220,000 psi. ARP Pro series kits are also available with 12-point nuts, and all kits come complete with hardened parallel washers for an even load distribution and accurate torque readings.
![](/proxy.php?image=http%3A%2F%2Fi5.photobucket.com%2Falbums%2Fy171%2Fsnakekillenws6%2FIMG_1599_zpsnno4rmv7.jpg&hash=d6ca314f70bc7607ecf0e84ed53baece)
![](/proxy.php?image=http%3A%2F%2Fi5.photobucket.com%2Falbums%2Fy171%2Fsnakekillenws6%2FIMG_1600_zpsgadkgonz.jpg&hash=1b0f38766574b769f4e2b7f1d26088c2)
Brand: COMP Cams
UPC: 036584028550
Locks Included: No
Brand: ARP
UPC: 672036001070
Nuts Included: Yes
Brand: ARP
UPC: 672036001032
Undercut Stud: No
Head Style: Hex
Cut to Fit: No
