cd player
to slow
What is the best years of cd players to install in stock location ,where to buy ,thanks Dave.
Unit I have in my 1984 GN—
Buick Delco #16085434 5 Band AM/FM/CD
This deck is out of '91 to '94 Buick B, C, and H bodies. And '92/'93 Typhoons as well. ; )
Radios- Stock type- 1.5 din
Almost all GM and Chrysler cars and trucks
On the F-bodies they are the same size but different mounting bolts
http://www.turbobuick.com/forums/general-turbo-buick-tech/267633-radio-options.html
http://www.turbobuick.com/forums/car-audio/27285-adapter-harnesses-gm-radios.html
Part numbers for compatible AC Delco CD Players? [Archive] - t6p.com - Turbo Buick Regal Resource
You can find cd units in junkyard most GM veh. brackets from your old unit will work with little fabbing. make sure unit has fan better for cooling.
i have an cd deck i took outta my car when i went with a sony head unit. if you want make me an offer with shipping and it's yours. the only thing you'll have to do is go to the junk yard and cut out a wiring harness from a GM car or truck from a late 90's model car. it should fit since i pulled it and the screws lined up perfect.
