May 19, 2010 #1 J jmendlik Active Member Joined Oct 1, 2001 Messages 769 Car 1986 TType Will these fit stock rearend w/o notch running 275-60-15 MT Drag Radial out back? stock rear end/brakes
May 19, 2010 #3 R Red Regal T Senior Member Joined May 24, 2001 Messages 19,243 They'll most likely work if you use a 7/16" universal spacer. You'll have to install 2" lug studs. http://shop.advanceautoparts.com/we...Stud-Pik-a-Nut_5018374-P_183_R|GRPWHELAMS____
May 19, 2010 #4 SCOOBY DOO BASED CANADIAN PATRIOT!! Joined Feb 18, 2007 Messages 3,909 Optimum backspace is 4". Grumpy runs 4.5"...but with a 1/4" spacer.
