SignUp Now!I've got a set that was run hard at about 1000hp and had a lot of street miles on them. The prior owner melted #1. up until then they had no problems. I see little point running those on a small bore engine. You could order the taller valves they use in a smaller diameter and run the std gn1 head.If you're making 1100+hp and running looser ex guides with a fast ramp solid you are going to be doing more maintenance to any head and have to have everything valvetrain related perfect or you're in for a lot of down time. You stay small on the cam and make less than 1000hp you can expect to get a lot more time out of them. You want to run a number the wallet better be ready for it.Anyone here running a set of aluminum Champion heads on their street car? How many miles have you accumulated & have you had any problems?
Anyone else have any problems with these heads?
Thank you
~JM~
....I see little point running those on a small bore engine. You could order the taller valves they use in a smaller diameter and run the std gn1 head....
Quriosity...Why then are you asking about the reliability of the Gn1-r heads? They are clearly not needed for your goals.
ok - so let me understand this correctly. champion gn1 r heads on a 109 with a .030 over bore would be a bad thing? The car is for the street and a a not very often on the strip. What would be some of the main drawbacks?
I know the valves will be a little shrouded. I am about the have block machined for the gn1 r to go on. Any tips tricks or just dont do it would be great.
P.S. - any questions on my combo - pm me and I'll get it to ya.
If your going to pay a machine shop to do all that work then you should look for a better block. You will have the same amount into it and it will be strongerthats one of the things that the machine shop is going to be doing and drilling and tapping 6 more holes on each side(from 8 to 14 each side), steel caps and a girdle. But I plan on overkill so maybe this motor will last longer.
quoted for truthIf your going to pay a machine shop to do all that work then you should look for a better block. You will have the same amount into it and it will be stronger
