Champion Fuel Rails, Accufab Regulator, Oil Preluber, Modified Fuel Hangars, Alky Kit, 80lb Injectors, Hot Wire Kit
GNVYUS 1
I'm trying to get back into the game and the game is still screwing me over. While I'm bending over I've got some things to sell.
Devil's Own Universal Alcohol Alky Kit $75
Shureflow Pump with 90 fittings, Hobbs Switch and Relay. This was my preturbo kit and has low low miles.
Preluber Oil Prime Kit with extra Pump $175
These were the thing for a while and mine is from ESP. This works and so does the extra pump and the brain box. The extra pump alone has to be worth $100.
Stock Modified fuel hanger with -8 -6 outlets $40
The float arm isn't accurate reading fuel on the analog gauge so you'll need to address this.
Casper's fuel pump hotwire kit $25
Works great had to go Racetronix for SS pump hanger.
These parts need to be cleaned, sit in solvent etc and THEN put on your car. These have the ethanol white chalk build up so DO NOT put these on your car unless you clean them. I know some members have the ability or patience to clean/repair issues like this so I don't wanna just throw these out.
Champion Rails, -8 feed and -6 outlet fittings, rear braided cross over AND Accufab regulator with welded -6 return fitting. $90
Stock modified fuel hanger with -8 and -6 fittings on the outlets. $75
This should clean up easily after a few minutes in solvent. Float arm reads accurate on analog gauge.
Seimens 80lb injectors $50
(MUST get flowed/cleaned and needs new orings) Do not install these as is, had low miles.
I can get more pics if needed, PayPal available and shipping is extra.
I will take the champion fuel rails with FPR please pm me PayPal info
Got it probably 2008 era straight from John since I live 20 minutes from him. Wire harness shell is dusty but all wires are in good condition.
Rail and reg SOLD
Can't find out how to edit original post so I'll do my best updating in posts.
The injectors still click when power applied? If so I’ll take them
I can't answer that on the injectors so I think I'll get them cleaned from a local Dsm shop and have better info and more certainty here.
Caspers Hotwire = SOLD
Both Hangars are available, which would you like?
ITSAV6, you were the 2nd person to contact me.
Alky Kit = SOLD
Here's what's left......
The float arm isn't accurate reading fuel on the analog gauge so you'll need to address this. Has upgraded Caspers wiring connector etc.
Bosch 044 Fuel Pump with SS outlet fitting $110
Low miles and used on my gas Talon, genuine Bosch bought new from Titan for $240, has a custom 3/8 outlet fitting so you can connect a normal fuel line hose to it in the sender. This will fit the fuel sender above but need a minor trimming of your fuel tank inlet to pass through if you want to run it in your GN. I did run these pumps in my GN around 2010 and the hanger is setup for this pump.
This part need to be cleaned, sit in solvent etc and THEN put on your car. These have the ethanol white chalk build up so DO NOT put these on your car unless you clean them. I know some members have the ability or patience to clean/repair issues like this so I don't wanna just throw these out.
This should clean up easily after a few minutes in solvent. Float arm reads accurate on analog gauge.Has upgraded Caspers wiring connector etc.
