firstbuick
Banned
- Apr 3, 2011
Parts Still Available
Many Parts Still Available
champion 1 1/2" plenum spacer new in box (w/gaskets) $80
champion 1 1/2" plenum spacer w/6 vacuum ports (no gaskets) $85
champion altenator bracket no a/c & no power steering (new) $150 SOLD
h & r parts poly transmission mount for 200r4 (used) $75
caspers fuel pump wiring harness upgrade kit #102028 (new) $40 SOLD
t-top weatherstrip seal gm nos qty 2 (new) $50 ea SOLD
a/c compressor gm nos (new) $195 SOLD
a/c compressor gm now (new) wrong pulley $150
direct scan tuning software box w/cables (win98 laptop needed) $100
heater box with no a/c (nice) $250
gm maf used (not aftermarket) $95 PENDING
pinion snubber aftermarket (new) $35
pinion snubber aftermarket (used) $20
motor parts
coil pack complete fits 86-87 turbo-v6 (used-tested good) $95
coil pack bracket horseshoe (used) $45
radiator hold down stock (used) $40 PENDING
battery hold down stock (used) $25
fuel rail stock (used) $45
up pipe stock (used) $30
engine hoist bracket stock (used) $25
main accessory bracket stock (used) $75
altenator bracket y-shaped (used) $30
timing cover stock (used) $45
valve covers stock no filler (used) $45 set
oil dipstick and tube (used) $50
transmission dipstick and tube (used) $45
oil pan 86-87 v6-turbo no pickup tube (used) $50
oil pan pickup tube (used) $40
pulleys stock used (assortment of pulleys) price varies
heads 8445 stock unported (used) $75
rods (2 dot) & pistons (0.030) stock (used) $50 complete
intercooler stock (used) $50
radiator fan stock (used) $40 PENDING
driveshaft stock gm (used) $50
egr stock (used) $20
egr plastic cover (used) $10
exterior
quarter windows blackout very nice (used) $125 set
t-tops locking w/out plastic trim (used) $150 set
rear bumper support aluminum $95
tail lights black $150 set PENDING
tail lights chrome $125 set
headlight bezels black w/side lights $125 set PENDING
wiper arms metal color nice $50 set
license plate holder metal $10
rear center filler for license bracket $25
body and door aluminum trim painted black no rubber insert $100 set
headlight trim metal holds headlight in place $15 ea.
Wheel well trim black driver front only (3) $45 ea.
Wheel well trim chrome passenger front only (1) $40 ea.
Wheel well trim chrome passenger rear only (1) $40 ea.
Windshield trim blackout 3-pcs $60 set
rear window trim blackout 3-pcs $50 set
trunk trim black $75
interior
center console gray no shifter, no base, no plate (excellent) $275
guage pod a-pillar single gray $20
t-top trim for locking t-tops passenger side only (nice) $50
third brake light gray (used) $30
door pull gray (1-set, 1 extra) $15 ea.
Door pull maroon (1-set) $10 ea.
Door panel lower gn concert sound passenger side only (nice) $75 ea.
Door panel lower gray concert sound (1 small hole in bottom) $125 set
door panel lower gray no concert sound $90 set
door panel lower maroon no concert sound (1-set, 1-pass) $80 set
door panel upper gray (2-sets pretty rough) $60 set
door panel upper maroon (1 set) $60 set
dash gray (i have 2 but they have splits on top edge) make offer
interior gray plastic parts (i have most of these parts available)
interior maroon plastic parts (i have most of these parts available)
motor parts
exterior
interior
