Champion heads bolt holes
workingdan
Getting ready to install my champion aluminum heads. just noticed there are 14 head bolt holes. Are all the aluminum heads this way? will they work on my 109 block ok?
Thanks Dan
The 14 bolt heads will work just fine, that is what I have. All aluminum heads are not 14 bolt.
Bryan
Make sure the bolts/studs are threaded far enough on the top right corners. If not double washer
