Detomaso71
- Feb 14, 2010
I have a sumped tank and engine is not at my house but I want to start gathering what's needed for new fuel line from b ack to front of car
Wanted to run external pump under car mounted by tank and run line to billet champion rails
Is 8 single to the railsand 6 return good for 9 second et at 3600lbs?
I hear some run 10an to and branch to two 8 and have two feeds to the Champion intake and then single 8an return with fuel pressure regulator mounted to drivers fender??
I don't wanna go crazy with this but I also don't want to upgrade the fuel system agin in a year either.
Ayone know rough feet of ss braided line needed and what fittings are needed to connct to the champion with 2 in ports and one exit to a FP regulator mounted 2 to 3 feet off the rail?
Also, does it matter what type of FP regulator I use that will accommodate a range of boost pressures? I see aeromotive has a lot of regulators is that what most use?
