SignUp Now!Originally posted by chevyII
from what I have found stockers ported flow as well as gn1s on paper,makes me wonder why so many people buy them.............
Originally posted by Intercooler
A friend of mine went from 12.3 to 11.7 with just a port job and back-cut stock valves. MPH from 110-111 to 116.5.
Well this car is the same one Frankg is talking about and I can say with certainty that it has less mods than the one you speak of that gained 80 HP. Having the extras would of course make that much more difference or else something is wrong.Originally posted by qwknuf6
111 to 116 mph= 50hp
121 to 126 mph = 80hp or more
Maybe you will end up with 50 hp gain for 850.00 ,I would spend the extra cash to get 80 hp ,afterall your paying for performance .
Build on this car:
TA-49
Stock IC, Stock D-5, 3" DP, 009's, Stock Motor, Stock IC, Stock TB, Test Pipe, Street Chip, 22 PSI. If it had an IC or bigger turbo, cam or anything to help with the breathing it would gain 80 HP with the heads.
Back-cutting the valves is cheap. Almost all cars need springs anyways whether to go with a cam or to replace high mileage weak units. Nothing wrong with a freshen job either. No core charge, no shipping charge for 85 lbs. of iron heads. It adds up!!
Maybe. He did run the 11.7 numbers with 5 PSI less boost so it picked up big. Reason he did the heads was because of a blown gasket and the car always smoked prior to this so who knows. It isn't too bad of a tune though..... I don't see many basically all stock cars with just a 49 and a set of ported heads going mid 11's on a street chip with pump gas on DR's.
