change 83 gn into sfi mad man. need help
ticketmachine
i found an 83 gn. the intake manifold is cracked bad. i want fuel injection and in the 10's. i have an 87 ecu and wiring harness. i'm going to build in intake manifold for it. i work in a custom turbo shop so my resource are close to infinte. my question, is there diferent sensors for the 83 to the 87 ecu and what is different for the motor them selves. i beleive the block and heads are different for the IC gn. the turbo placement is going to be change and it will have a front mount IC. i'm also removing the fan shoud and fan for an electric fan ( i'll need the space). Also i'm going to use an LT1 mass air and translate it. any help would be useful.
thanks
mark
have an 85 setup
i have 85 intake and turbo setup if interested.header needs repair.can use 87 computer on it.have 84 t wiring. they do have intercoolers for these intakes too. also have heads(8445)
andy
complete 87 engine
if you interested my brother is selling his car 87 t engine was rebuilt but never finnished.lunati cam,30 over pistons 2800 stall.complete car he says $3300 takes whole car.it would have any sensors and other needed parts.1/4 panels are rusty but rest is usable.has buckets and floor shift,tilt,digital dash ps,pb,pw,pl,ac,pseat.,14 in crager sst,in pieces worth much more.
andy
email apierce72@comcast.net or call 708-594-3912 leave message,thanks andy
located south side of chicago il
