Changing deep sump
jdpolzin
Hey guys, just a quick question because I am foriegn on tranny's! I have 2 GN's they both have a D5 converter 2800 stall shift kit blah blah. One has a deep pan and sump and the other doesn't. I want to put that pan and sump on the other one and vice versa. I believe the sump is just a tube that has 2 bolts holding it on, is this correct? I can pretty much just pull this out and put the other one in right? Anything difficult that I have to watch out for? I know it may sound dumb but I just want a walk through before I go in!! Thanks guys! ----Jeremy
There is a way to use the 700-4r Filter. They say it's better than the stock 200-4r filter. Look into that, do a search on 700 filters. HTH
Ok, well the issue is that I already have a deep sump and deep pan in one and I need to put that in the other transmission. Then put the other sump and pan into the one the had the deep sump originally.
