70Firebird/TTA
- Aug 11, 2002
This might seem like a lame post...but I wanted to make sure I was doing this right.
The rubber plug on the diff case lid can be pryed off with screw driver???any recommendations as to the best way to do this as to not damage the plug? I am thinking of using a hand pump to suck out the old fluid through the hole inorder to avoid having to replace the case gasket. Has anyone had any luck doing this without removing the case lid? My TTA has 25 grand on the odometer and thought it would be a good idea to change out the fluid...not to mention readd GM Limited SLip diff additive.
Any recommendations are appreciated.
David
David
