Changing water pump
GNguy
U aint that big
How hard is this job? What all is needed to do this? Never done it before but I have changed out most things in the car, anything I should look out for? tips? thanks
it aint that hard jeff, remove the belt with a 18" socket, remove the 1 hose that sits behind the turbo, remove the radiator hose that goes to the water pump, remove the bolts to the water pump and clean the threads off with parts cleaner, apply thread sealer to the 4 longer bolts from the water pump, apply a small (light bead) of silicone just to hold the gasket in place so it doesnt move on you while installing it, reconnect hoses and adjust the coolant level and your done......i forgot to mention if you have a stock location intercooler it might have to come off as well
Thanks Ziggy, Ill be doing this today, hopefully it goes well.....
