Sometimes I notice the BAT display on the Scanmaster drops to volt values in the very low 11's and sometimes even the high 10's. This does not seem to correspond with any specific driving conditions or accessory use, and the voltage output does not seem to change with engine speed. I've replaced the battery, both battery cables and the alternator with no change. The problem does not occur all the time, but I'm worried that it may get worse. What should I check next?
