Charging System
cutt
Alternator Test Good But Car Still Dying After Draining The Batt
sounds like you have someting going to ground. Need to do a draw test. Disconnect the neg batt cable, take a test light and touch one end of the test light to the batt ground cable, then take the wire/clamp end and touch it to the neg post of the battery, effetively putting the test light inline with the batt neg cable. If the light lights up, you have a draw. Then, you can start pulling fuses and if the light goes out, the draw is in that circuit, provided there is only 1 draw.
BTW... did you have the battery tested ?
kill while runnig
this vehicle kill while driving as if the alt is not charging
Many things can make your engine die....Yes, it could be related to your charging system....A scan tool will tell you if your charging system is up to par or not. Scan tool readings will also show many other systems and sensors that are not up to par. :)
