1KWIKSIX
- Sep 29, 2007
Suspect I have some vacuum leaks leading to my high BLM's (139 cold & 151 engine warmed up). INT's are perfect at 128. My boost /vacuum gauge reads 21 inches vacuum at idle. I'm going to inspect the vacuum lines closely for cracks and replace if req'd. Finally was planning on using some SS Safety Wire and Safety Wire Pliers to secure each hose . I've heard of people using a touch of hair spray on the hose barbs before inserting lines. Is there any other proven product used to help seal these lines? Thought I heard about using clear nail polish?....I was thinking if this was the case, I may select this.....as the small brush / applicator would allow a light coating around the entire circumference of the hose barb. Any suggestions or thoughts? Recently installed Extender Extreme Chip and GEN II Tran + LS1 MAF. Had noticed the AF previously was 05 with the stock MAF and TT chip but is reading considerably lower now with the new set up. AF is reading 02 on start up when engine is cold then goes to 01 when warmed up. I've heard that the AF readings are sometimes lower when using the extender chip? Is this normal?
Here's some readings off scan master after car warmed up.
AF 01
LB 21
BAT 13.0
INT 128
BL 151
CLT 173
At5 71
r 825-850
tps .46
IAC 19
cc 00
Anyone?
Thanks,
Dave
AF 01
LB 21
BAT 13.0
INT 128
BL 151
CLT 173
At5 71
r 825-850
tps .46
IAC 19
cc 00
Anyone?
Thanks,
Dave
