First of all thank you for the replies, today I got a bug and decided to trouble shoot the turbo to see if there were more signs of blown seals and to my surprise there was just a slight sticky coating of what I think is some form of oil build up on the outlet side, it didn't look like it would cause any issues as it was dry and had to really smear my finger on it to get some on it, the compressor side had a little bit of the same but slightly darker like caramel but again very thin and dry, the exhaust side was mostly  dry it had a spot that looked slightly cruddy right behind the center section of the blades. With that said also checked for play on the shaft and there was no noticeable movement in any direction but 2 of the blade tips looked curled back on the compressor blades. After having cleaned the center section it looks like the drain back is what is leaking outside of the turbo, I'll double check that it is working properly when I replace the gasket.
As for fuel I pump 93 and 100 from the Sunoco down the street I have tried different octane boosters because gallon to gallon it is cheaper and 93 with NOS octane booster gets rid of knock completely.
How do I check if the ECM has been modified for the lower impedance injectors? The chips were made by a shop back in the late 90's early 2000's they have written the specs of the tune one of them says "55#inj-22*timing street tune."
