SignUp Now!This is just my opinion. Rear disc brakes on these cars honk on bobo.
While I haven't actually purchased the Scarebird rear disc brake kits, I priced out all the extra parts you would need like calipers, rotors, pads, etc. and it came out to like $330 for all brand new parts and that is including the scarebird kit. Priced it via rockauto.com.
in the 90's, the S10 went back to the old school 4 bolt axle flange pattern- there is NO oem rear disc brake caliper bracket that is a direct bolt on to a G body. none. nada. zip.I've got ed miller's brackets to run 89-97 (yes they overlap generation) calipers with 11.6" rotors.
the ebrake cable will interfere with the shock, so a bracket is needed to relocate the shock.
I am now considering using 98-05 blazer brakes on the rear because of the ebrake setup, but I read that the blazer brakes require a 1/8th inch spacer to fit on s10's with rear drums, so I assume the same is true of g-body's.
perhaps I could use the 4wd blazer backing plate and swap sides so the caliper is still behind the axle tube (frame clearance). this would only be beneficial if the 4wd backing plates to not require a spacer as the 2wd does.
I just hate adding a spacer when I can avoid it...
every car and truck that got rear disc brakes that GM ever built for north America (except for Corvettes and the 82-92 F bodies with the Borg Warner rear axle) uses the same 4 bolt flange. the 82-92 F bodies with rear disc all had the Borg Warner 9 bolt rear axle, and it uses a slightly different pattern than the other GM cars and trucks.
