I'm thinking about taking this thing apart and lubing it real good before installing it. What kind of lube would work best?
I'm also going to replace all the light bulbs for good measure when i find out which ones they are...they look like either 168's or 194's.
Something else I found was the circuit track is starting to come up where the plug in connection goes:
Wondering what you'd recommend to secure this with? Superglue?
Last but not least, I'm also deciding on if I want to omit the tachometer and boost since I already have an Autometer boost gauge and I can use my Scanmaster's tach if needed.
I know the n/a Regals came with a different bottom plate that didn't have the tach. Has anyone swapped one of these onto their GN/T-type's speedo assembly? I'm guessing it's a direct bolt on?
Anyways thanks in advance.
