Chicago Trading post II
PTE 70MM plenum. Looks new. Maybe 500 miles on it. Non chromed one.
$100 picked up West Suburbs
I have a complete set of stock/original brake lines and a complete set of stock/original fuel lines if someone has a use for them.
Sorry for leaving out some details.:redface:
No they are not new. They are off my car, used.
Same for both brake and fuel.
looking for
-aftermarket 1piece front air dam/spoiler.
-aftermarket rear brakes for late big ford bearing end
-parachute, mount, cable, lever
If your lookn to set up a roller, I might have a rusty set of control arms..
i have a rear in powdercoating jail so im looking to be able to get my car off the jackstands. i have a few poeple who responded but i will let you know...thanks.
jeff,
i have a mount and a lever but i have no idea what its for. you can have it!
King size bed with good mattress and chest with mirror - $600
Hello guys, I have a few parts that i need to get rid of.
chrome and black taillights, both in good shape.
fenders already cut for louvers they paint is already stripped off the fenders.
ecm for an 87 regal.
2 front buckets off an 84-85 gn tan and leather in good condition.
make me some offers.
if you still have the tan seats, how much do you want for them?
SGI /EAGLE CRANK/K1 Rods
I figured I would offer this stuff local first as I no longer need it.. Standard bore SG1 with caps $400.00.. NEW Eagle crankshaft 3.400 stock stroke $750.00.. and NEW k1 rods stock length..$650.00.. CAT flexplate clearanced for Eagle crank $50.00.. thanks Ed
I have a set of centerline warrior wheels. 15 X 8 rears and 15 X 4 fronts. Fit turbo buick with no problems or spacers. $400 OBO.
I also am about to have an available scanmaster, ANS knock alert, and a stock ECM with MaxEffort thumbwheel set up and three different maxeffort chips for 83# injectors. Also several aftermarket interior trim pieces with turbo 6 logos, that I'd like to get rid of (dash plaque, shifter plate, ash tray cover plate, turbo 6 door pull strap extrusions (sp?), etc. Also a buick motorsports radio delete plate. You can see these items in the pic below, I want to put the interior back to a much more stock appearing state.
How much for the scanmaster?? and is there a difference between versions?
75 lb injectors $200
Chrome fuel rail $ 75
Adjustable fuel regulator $ 75
4" mass air pipe RJC new $125
RJC aluminum crank pulley $125
for use with crank fan
coil adapter for msd dis 4 $100
Steve
Steve
Steve. I'll take the chrome fuel rail. Any luck with the drivers header? Call u later tonight. Thanks
looking for GN/REGAL rear window glass with defrost
I used to have one of these. I haven't seen it in a long time but i'll look for it..
My items are still available:
Gn grill $100
Graysish steering wheel $30
Dark blue? wheel $20
Grill has one broke plastic rivit.
Also,
for my fellow gun nutz
I have three original Russian rifle crates for long term storage.
Mosian holds 15 $50
K98 Mauser 15 $75
K98 Mauser 20 $75
