Chicago Trading post II
DoubleD said:
I think I have 1 good shaft in my storage unit. I think it might be an HD shaft. I am not sure if it has buttons on it or if all the rockers are loose though.
Let me know if you want it.
Yes, ill take it.if u had the set would be better .:-).
TurboBuRick said:
No dice on the rockers. I can't believe there is not a set laying around here. Someone else will chime in with a set I'm sure.
I do have a set of rjc rocker shaft braces though.
Is it for like the link says? 2 for each corner? Would i have to get different size bolts? Thanks Jason for clearing that up.
I do have the set, however one is cracked. I have all the rockers still. I think they are sitting inside a set of stock valvecovers too if you want those lol
I have a set of stockers. Use these and the RJC braces and be done. Now if you rev it to 6400 rpm Good Luck! I am near the Hillside Carmax. I am off work tomorrow. I had a set of HD shafts crack on me. I have better luck with stockers. Let me know if you need them.
Deal, price me, are u by the old menards? The one closed down? No is just a mild engine dont see more than 5500.. Shoot me a txt 708 2097872 i can pil up tomorrow any time im off as well.
60 lbs inj with tt chip. 240 or trade for a cold air intake like tinman or big mouth from tr costums.
7082097872 txt me with what u got.
Chrisk said:
I have a set of stock original axles. About 80,000miles. Splines are perfect. $50.00
I also have a stock unopened long block. Also about 80,000 miles. Includes intake to oil pan.
Intake and heads have never been removed. Can probably push some boost on that factory head seal.
Make offer on the Engine.
Still available.....
Engine is SOLD.....
Can we start a Chicago Trading Post III ??
Anyway, I have a TA49 with low miles.
Make offer...
Add $50 if you want the compressor housing powder coated.
Located in Mundelein.
PM me a offer, most I can do is say no or give you a counter offer.
I'm looking for a rust free 8.5 rear housing. I actually prefer it completely bare as it will be built with all new components, but will entertain a full one if you have it.
Stock rear sway bar.
Free..... Come get it.
Stock intercooler with shroud. Perfect condition.
$100 obo.
Stock torque converter. Make offer.
TA49 turbo still available.
67 mm garret dont kno much about it..
500$ firm.. Pm for Q's low mile rebuilt, stated by previous owner. I never used it.
Parts for sale tomorrow.
A friend is stopping by who has parts for sale. Cheap!!
TA49 Turbo.
PowerLogger.
ECM with alky chip.
Old SMC Alky kit with pump and all. works.
Innovate WB brand new.
Stock injector harness.
Stock fuel rail.
Stock Intercooler.
Stock axles.
Stock Torque converter.
Theres more but can't remember off the top of my head.
All parts will be available tomorrow morning in Mundelein.....
Rcj boost contoler. $30
Front end brace kit( lower) $30
Stock intercooler everything on pic $100
Our the brace kit and the Rcj boost controller available?? if so, is the brace kit a direct bolt on?? meaning no drilling holes on the car
