Chip for my combo?
Mustang 1
Hello everybody and thanks in advance for your imput!I have a 87 GN with the following upgrades:
PTE 52
CAS V-4
009 Injectors
2800 Stall
T.H. 3" Downpipe
3"Dynomax Supershot
BstC oost Controller
I mix my fuel with a combo of 110 leade and 93 unleaded.Avg 98 octane.My car was ran without the stall converter on straight 93 back in 10-01 with the stock intercooler and ran 7.99 best time in the 1/8th with a very bad 2.20 short time.The car currently has a hot street chip from Cotton's for the stock injectors and 93.I adjusted the wastegate for a range of boost from 14 to 22lbs.I must run around 30lbs static to avoid lean condition at 20lbs and higher of boost.Car runs kinda rich but I still avg 17 to 20mpg.Havn't run with current combo yet.Thanks for you help!
Jim Testa unless you want to get into a ME or Trans+/Extender set up. I believe Jim posts as Turbojim. Shouldn't be hard to find him in here. Good luck. :)
