Turbo Riviera
- May 29, 2001
I have a couple of questions that I think are best answered in this forum rather than general tech.
I have an '84 Riviera turbo that I'm having some trouble with.
It rich fouls plugs after 2-10 passes. average is about 4-6 runs. Then I have to put new plugs in. I feel it is the O2 sensor getting whacky from the C16 I'm using that's kicking up the idle BLM to 160 on DS. I don't think that it's a function of the WOT runs fouling the plugs... It think it's the idling around in the pits and on the return road that does it.
The car is an NHRA Stock eliminator class car so I have to keep most of the stock parts.
Here's my combo:
Stock long block '84 hot air 80,000 miles never rebuilt
no port work
stock turbo
stock cam
ACR44TS plugs
electric fan
'87 ECM, MAT, MAF
K&N
3:36 gears
10.5" TCI lockup conv.
26x9 Hoosier slicks
2.5" fabricated mandrel bent DP
2" fabricated mandrel bent x-over
stock headers
20-21 psi boost. (currently manual valve ajustment, would like to go back to boost solenoid IF it will make the car more consistent at the track)
3810 lbs race weight.
Front wheel drive
XP pump hotwired
27 deg. Red Armstrong chip
Best un-corrected 1/4 mile time:
13.63 @ 98.90
1.870 60 foot
This is a dedicated race car that sees zero street use.
I'm thinking about sticking a maf translator on it to adjust the fuel somewhat. Ultimately I think this is a band-aid for an improperly calibrated chip. Can someone make a chip that will not foul out my plugs? Jim Testa? Dave Huinker? Lets hear your opinions..
I normally race at altitude tracks between 1300 and 5800 feet. Should I be changing chips for different altitude tracks? I think the answer to this is yes. I currently am not. I use the same chip for all tracks. I trailer the car to the track so there is very little learn time for the ECM to adjust to different altitude.
Over the winter this car will be getting the following:
3 angle valve job
Lunati 226/220 cam .411 lift (stock eliminator grind)
A/C deleted
electric water pump
Power steering deleted
Goals for the car are 12.90's @ 100-102
I'd like to be able to just wire the wastegate shut (I feel the car will be more consistent this way) I know that I'll be pushing the limits of the stock turbo by doing this. Actually I'd like to exceed the limits of the turbo if the truth were known (thus the reason for the monster camshaft) I have to keep the stock turbo to be within the rules of my class and I'd like to know that I'm getting maximum airflow out of it. By wiring the wastegate shut with an engine that exceeds the capability of the turbo this would obviously lower the maximum boost. With this lowering in boost, should I be able to kick the timing up a bit??? Cylinder pressure would still be high, but charge air temp would be down.
Just thinking out loud here guys. What can we do with this turd?
Thanks in advance!
Here's my combo:
no port work
stock turbo
stock cam
ACR44TS plugs
electric fan
'87 ECM, MAT, MAF
K&N
3:36 gears
26x9 Hoosier slicks
stock headers
Front wheel drive
XP pump hotwired
13.63 @ 98.90
1.870 60 foot
3 angle valve job
A/C deleted
electric water pump
Thanks in advance!
