Boy O Boy Am I Having Trouble Installing This Servo With The Trans In The Car,,,,i Removed The Stock Gn Servo And Installed The Billit One Believeing That The Pin Was At Its Proper Place In The Band,,as Spring And Pin Stayed In The Pin Hole And Band Or So I Thought ....well After Installing New Servo And Road Testing The Trans The 1 2 Shift At Half Throttle Is Flareing So Badly That I Believe That Pin Is Not In The Band Hole...soooooooo I Redid The Whole Thing Over With The Trans Pan Off ,i Secured Band On The Inner Part Of The Trans With A Long Screwdriver Weged Between Band And Case And With A Light And Mirror Tried To Aleign With A Small Screwdriver The Band Hole So I Could Slide My Pin And Spring In ,,,then I Installed My Ck Billit Servo ,hoping It Was In The Right Place,,,,,i Am Right Back To A 1 2 Flare Helppppppppppppppppppppppppppp
