SignUp Now!Originally posted by norbs
I want to know your rpm drop on the shifts @25 psi. If you shift from 1-2 at 6 k whats it drop and and also 2-3 , right now mine is 6100 and no rpm drop in the shifts at that boost level
This is why i am thinking about the ck perf. 9/11 converter as my next converter. MY local tranny guy fixed the tranny said the drum was warped band was not a wide band and the direct clutches burned. So now i don't really want to put my PI converter back in. How do test the effiiencies of your converters again? LIke you said if its too tight it can spool and if its too loose it will slip on the top, where do you draw the line?
