Got my CK kit in today. Fairly simple. The instructions didn't say anything about the pressure regulator assy in the pump. I had Chris's manuel and 3 years in a trans shop exp so it wasn't too hard to figure out. I also removed the cup plug in the valve body for the bleed on the 2-1 coastdown as per the manuels instructions.
Got it together test drove it. 1-2 short and firm,2-3 fimer than stock but softer than 1-2,3-4 just like 1-2. Cool. Drove some more and noticed the trans starting in 2nd gear. Shifted to 1st while stopped and felt a bump as the trans went into 1st. Did several start and stops and exactly the same thing 2nd gear starts
shouldn't of removed the cup plug. Then while coasting down the TCC does't let go and car starts bucking geeting ready to stall cause it's in 2nd. Shift to 1st,cars idles normal as TCC is unlocked in 1st. Take off and everthing is the same. Start and stop some more and now it starts going into 1st like it should everytime on the coastdown.
All valve were free when I installed the valve body. Pull out into traffic and hit the gas,as soon as it hits 2nd engine falls on it's face as the TCC applys instantly
,pull over unplug it. Still does it. Get pissed off drive home and I nail it,then crusing notice the TCC isn't locked anymore. Now trans acts normal with the exception of no TCC since it's un plugged.
I am a little confused,and thinking I should replace the TCC and see if I can find another cup plug and reinstall it in the valve body.
Anybody? This is a 57k virgin trans/car bone stock. Trans is in excellent shape as is the rest of the car. It's a document 1 owner old woman car,Kirban car at that.
