classic fast and nitrous maps
turbo6man
Hi I have a classic fast and I do NOT want to control the nitrous solenoids with the fast, I only want to enable the fuel and timing tables. I called fast and they said to just wire 12Volts to pin L2 which is n20 enable.
My question is this: when I hit the nitrous solenoid through a button, the relay that provides 12v to the solenoid, can I use this 12V for the fast enable wire which is pin L2?
I have heard that solenoids can cause a voltage spike when the button is released,which can hurt electronics? I do not want to hurt the fast. What do you think
Also special thanks to Cal for graciously giving me pins to hook the wire up to my fast connector
