Warp6
Mine since '92
- May 25, 2001
Renaming the folder back to Config was what it needed. I can now make AND save changes on my desktop. Thanks Cal.
SignUp Now!Ahh, now we are getting to the bottom of this. You guys never mentioned swapping computers. The reason you can't do this is because the other computers are in "Demo Mode" and have never been connected to an ecu. Connect to an ecu once and it will be fixed. Or you can transfer your FAST config folder to your other computer and it will go out of Demo Mode.
Well Cal,
It will not work if I close the program and rebout. The ``Save ALL Tabs`` will not appear open.
It won't appear because ther isn't any program loaded in the FAST, yet. That requires hitting "Read All Tables" and loading a program.
Have you tried doing exactly the 6 steps I posted earlier?
Yes, but do you see what you said. You never mentioned that I can shut down the Computer and open the FAST and make any changes to my File after. Only if I never close the C-Comp then I can make as many changes I want out of the car. And I think is what we seem to have a mis-uderstanding.
J-B Racing, I'm sorry for getting your thread off your track. I thought we shared the same problem.
I think it would help if you describe step by step what you are doing.
Joe, I think I know the problem. Please connect with your ecu and let me know what it says your ecu serial# is.
That is exactly what I suspected. Now the bad news, NOW I will need your ecu serial number off the back of the box. Once I get that, I will need your email so I can send you an option file that will make your ecu work properly.
I think I can still get this fixed for you.
