I'm cleaning up some wiring on my car while the motor is out. I have a Classic FAST. I noticed that the IAT sensor was not utilized and now I want to use it for logging purposes. I got a new sensor and installed it on the back of the lower intake. Previously, there was not IAT sensor on the intake pipe, IC up pipe, etc..???
When I found the plug, I noticed this plugged into it? (See pic, Long black plug near my pinky) The loom has two other plugs that goes between the cam sensor and stock harness and goes straight to the 3 bar map sensor. If I want to use the IAT, do I just unplug it from the long black plug that goes to the map sensor and plug it in to the stock wiring harness??
An input is greatly appreciated. Thanks
