Classic FAST SEQ. Car wont start!
The A/F raito is on 15, I am getting no O2 correction% and the UEGO (V) is 3.53. All this with the car running at Idle.
Is the missing problem solved? Raw fuel or un-burnt fuel will set the O2's off and make it look lean when it's not... it's just a constant miss.
Your Injector open time could be off. That'll make it run terrible too. Try several places up or down on that setting and see if it helps.
Might be a 1.0 right now.. I've got 83's and have it set at .9 But every injector set is different.
What RPM is your O2 correction set to begin and end at? Is closed loop even enabled?
Send me your current run file.
~Scott
UR50SLO@aol.com
What was the fix?? i am now having the same problem on my car. CAr died going down the track and has no injector pulse. On the fast box the A-D and E-H arent flashing back and forth. A-F stay on and G-H blink...messed with it some and then A-F blink and G-H blink...car is getting fire and fuel to rails but not pulsing injs.
