May 2, 2020 #1 stg1dom Stage 2 GN Joined Feb 11, 2005 Messages 46 I have a classic FAST plug and play harness and I forget where the pink/black trace wire that comes out of the WB O2 sensor goes. Thanks in advance Attachments B3D0341B-53D5-4848-9AFD-6AB33CA9E19A.jpeg 1.3 MB · Views: 217
May 2, 2020 #2 pacecarta LOGGED OUT Staff member Joined Aug 1, 2003 Messages 9,736 its for the injector power . on the injector harness cut the pink/blk (12v ) wire about an inch from connector , attach the end that goes to injectors to the wire from FAST harness (seal off the other end )
May 2, 2020 #3 stg1dom Stage 2 GN Joined Feb 11, 2005 Messages 46 Thank you sir! Sent from my iPhone using Tapatalk
May 4, 2020 #4 C cutt Member Joined Aug 11, 2002 Messages 336 does your check engine light still work after fast install?
May 4, 2020 #5 pacecarta LOGGED OUT Staff member Joined Aug 1, 2003 Messages 9,736 check engine doesnt work with key on with FAST classic or XFI , but XFi does have check engine light for codes
