Classic Fast with 2 bad injector drivers
JDB
It appears that we have 2 bad drivers in this sequential box. We are running a 4 cylinder and I am wondering if it is possible to simply connect to 2 of the unused injector wires and continue to use the box.
If so, would it be possible to maintain the individual cylinder control of fuel?
Thanks,
JDB
if you are going too run it only as a 4 cylinder box you could (if your capable) move the injectors drivers around.
I would contact Craig though as HIGHPSI said and have it fixed properly
Connecting to different outputs is not an option with a sequential unit. With a B2B you could do it but not in this configuration.
I can fix it if it's broke. I'll respond to your PM with more info.
