Thought I would post these pics and maybe motivate someone to do some cleaning....a frind of mine had cleaned the bottom of his car spotless several years back and it motivated me to clean my TTA underside with a small brush over several months until it was showroom clean again after 28k miles!... So now my engine is out of the GN for a rebuild so I took on this project...I did not clean everything, pretty much stopped after the back of the front tires on the frame, you can start getting into a lot of work fast if you can't stop or set some boundaries on what to clean...and didn't touch the A-frames as they are a mess
What it looked like to start with:
Used lots of rags and gas to get the wax like coating and all the grease off...this frame has 57k miles on it BTW..
Then a coat of primer, and 2 coats of semi-gloss black:
[/URL][/IMG]
