Cleaning out the garage, make offers
Jeremy
The shift cable can be purchased at advance auto. There are three different lengths to choose from. You will have to match it up. You might have to enlarge the hole that hooks onto the shifter but they seem to work ok. As far as a trans bracket, I'll make a few calls. Are they OD specific? If I can't find one I bet the packrat has one!
license plate bracket
how much for #39? this is the piece with the springs that covers the gas tank fill correct. It will need to be shipped to 21009 thanks.
Therein lies the problem. My '78 currently has a column shifted Metric TH200C. I picked up a CQ code 200-4R this past weekend, and ordered an Iceman crossmember for the trans and a set of PMT control arms so I can finally finish swapping in the 442 8.5" rear I picked up this summer. I also have the floor shift column from my previous Regal in the garage, so basically a correct length driveshaft and a way to shift the trans are all I need to finish my driveline. But having never dealt with one of these transmissions before and having nothing to compare to, I'm hoping for bolt in parts.
On that note, I guess I also need to find the correct bracket for the TV cable as well.
Another Update---#4
1. stock Innercooler
2. throttle body (complete with sensors and throttle cable bracket)
4. main accessory bracket
6. a few power steering lines
7. tensioner pulley
9. 2 sets of complete 8445 heads
11. electric fan
14. fuel pressure regulator (stock)
15. oil cooler adapter + lines PENDING
16. 1/4 glass windows (chrome for vynal top)
17. Inner cooler fan (2 of these)
20. Vinyal top chrome trim
21. hotwire to alternator bracket
24. All the EGR components
25. turbo inlet bell
26. Down pipe elbow
27. MAP sensor
28. 86/87 heater core
29. heater control valve
31. Charcoal canasters
32. Vacuum boosters
33. stock upper control arms (rear)
34. heater box fan
35. 85 Chrome Regal grille (NICE)
36. IC bracket (drivers side)
38. INJECTORS (42.5# set of 8, low miles)
39. Lisence Plate bracket (rear)
40. License Plate Bracket (front)
42. CAM Sensor w/o cap
44. Stock Starter 34K miles
45. POWERMASTER (Cardone Reman 2-3 years old, Accumulator went bad, otherwise good)
46. 14 bolt oil pan (Cleaned and painted black, non-baffled, NICE)
49. AC Delete pulley (2 of these)
50. 4.1 Stock pushrods
51. 14 bolt front cover (cleaned needs two bolts drilled out)
52. 20 bolt front cover (ready to go)
53. Oil pick up tube
55. Chrome Parking light bezel for bumper (nice chrome)
56. Woodgrain dash bezel
57. woodgrain radio bezel
58. Floor Shifter assembly (no handle)
59. Boost Solenoid
Make Offers guys, I want this crap GONE!!!
Another Update---#5
7. tensioner pulley
11. electric fan
26. Down pipe elbow
27. MAP sensor
32. Vacuum boosters
34. heater box fan
59. Boost Solenoid
60. GN Steering Wheel (Good for a core)
