Im tired of tripping over stuff
All parts are off 86-87.
3 20 bolt oil pans,1 fresh painted black,1 fresh painted grey,the other is a nice stock pan thats needs cleaning and painting.All nice pans.2 painted ones,$50 each shipped,1 unpainted $40 shipped
set of stock rocker shafts $20 shipped
stock crank pulley $30 shipped
stock water pump pulley $25 shipped
stock elec fan $45 shipped
stock exhaust elbow $40 shipped
stock PS header w/ broken bolt in xover flange $60 shipped
used ARP main studs $30 shipped
used 3 to 4 bolt turbo adaptor $40 shipped
boxed lower control arms with newer rubber bushings $55 shipped
used ARP head bolts $30 shipped
used 20 bolt front cover in good shape $30 shipped
used stock floor shifter $35 shipped
used positive battery cable ok shape $15 shipped
86-87 hard heater lines $45 shipped
85 GN grill,silver top,silver bar in the middle,excellent shape for a driver with no breaks or chips $60 shipped
core support x brace's $30 shipped
used underhood cruise control diaphram $30 shipped
used wiper motor $25 shipped
wiper assembly $30 shipped
maroon console complte but the top is busted up,bottom part that always breaks is mint,includes console door $65 shipped
GN console top with no door $45 shipped
used starter $35 shipped
Caspers TPS enhancer $55 shipped
used boost solenoid $20 shipped
used IC fan,good shape with no broken/cracked blades $45 shipped
used 86-87 upper rediator hose,good shape with bracket to attach to alt $25 shipped
11 used plug wires,Crane and Magnecore,Cranes have about 1k miles and 1 end pulled off $25 shipped
used gauge cluster out of 59k floor shift car $65 shipped
used Buick Regal stereo install kit with wiring harness $15 shipped
new Buixk Regal stereo install kit with new wiring harness $25 shipped
stock upper and lower front control arms,both sides $110 shipped
L&R grey sun visors,good cores for recover,comes with brackets $35 shipped
used 86-87 injector harness,good shape $35 shipped
used 86-87 idler $30 shipped
used 86-87 idler bracket $35 shipped
used AC comp,worked when pulled,no garuntee $25 shipped
3.8 Regal frame mounts $40 shipped
L&R headlight bezels with turn signals,not broken but need paint and turn signals have cracks $25 shipped
used dash cluster out of 82k GN,wiring in the back has been cut $15 shipped
used H&R Partsnstuff poly engine mounts for 109,like new with install hardware $155 shipped
used stock motor mounts,good shape,maybe 1k miles $20 shipped
I accept paypal if you pay the fees.All parts are obo.Thanks.![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
![Wink ;) ;)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
