Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
Anyone use this?
SignUp Now!Jerryl,
Can you post a link? I did see where autozone had some 3M spray on protectant I might try.
Good info. How long ago did you do this?I have pulled lots of the older 3m off that was molded maybe it has changed
Thanks. Sounds likd it might be worth a try, especially on a car that sees very little sunlight.I do it a few times a year. The newer stuff I figure is better. Most I pull off is from 04-07 been on there a while. Lots of times I have had to use a razor blade and scraper. Bad bad and repaint. But being at the bottom of the car would be better because the sun is not directly on it, but black or dark colors gets so hot it bakes on.. I pull it off of motorhomes front-ends win wrecked or it needs replacing
Thanks. Sounds likd it might be worth a try, especially on a car that sees very little sunlight.![]()
