- May 25, 2001
How much clearance is there between the oil pick up and the pan usually? I am going to be dropping the pan in my car and I noticed it is dented pretty bad (was deepened about 1", pickup extended the same)
SignUp Now!I took my stock shortblock apart a while ago the way it came from gm and the pick up was 1/2" from the bottom of the pan. I have read that some people like it closer to 1/4" of clearance. I recently put a new engine together with 1/4" pick up to pan clearance and have run the car a lot and quite hard with no issuesHow much clearance is there between the oil pick up and the pan usually? I am going to be dropping the pan in my car and I noticed it is dented pretty bad (was deepened about 1", pickup extended the same)
I would just take the dent out and save yourself some money.the center part of the pan looks to be about 1/4" dented in vs the edges. I might just order up a RJC pan on monday. Melling or Speedpro for a replacement pickup?
1/4" is a good clearance for a wet sump application. Put a plastic bag over the pickup and an ball of modeling clay on the bag. Bolt the oil pan in place and let it deform the clay. Measure the clay.
I would measure how far the pick up drops down and then pound accordingly to get your 1/4" clearance. The pan actually looks pretty good. I would use it for sure.Finally got the pan off tonight. Here is how it looked:
View attachment 159629View attachment 159630
I will have to pound it out tomorrow. It should just be flat across the bottom correct?
I did notice that the guy who did this pan also put a baffle in the front, made it a bit harder to drop the pan but I know oil will be down at the sump when I break hard
Have to stop at the art store tomorrow and pick some up. Is the cork gasket (Duttweiler one) similar thickness as the blue felpro? I thought I had one, but it was a rubber felpro one and it will take a day or two to get one shipped here. I'm also going to order up a set of HR mounts, there won't be a easier time to do them unless I pull the motor later
