Clearing out again......lots of stuff+pics. Some show some cheap
jdpolzin
Show quality very nice stuff:
1. GN Poston Door panels (NEW) were cut for a manual window but will just need to be opened up for power windows if thats what you have. Very nice. $200
2. Modded 20 bolt front cover, all Earl Brown mods done and mellings high volume oil pump kit installed. This hasnt been on a motor since it was re-done. Very Very nice. $225
3. Ceramic Coated Uncut Turbo Sheild, extremely nice, hasnt been installed since the coating was done. You wont find nicer than this. $115
4. New ACDelco Lifters, entore set of lifters never used, never opened, $135
Regular Parts (CHEAP):
1. Complete Intercooler Kit (intercooler, shroud, IC fan, both IC brackets), the shroud will need to be re-zip tied cause it a little loose on the bottom but it's in over all good condition. A few paint flakes off the top of the IC. $125
2. Stock Rockers 59K miles------- $20
3. Stock turbo, little bit of play but still in good shape, no smoke, just took this off the car, no accuator but includes inlet bell, there is one bolt broke off in the exhaust housing that will need to be drilled out. -----$100
4. Front Cover 14 bolt, came off a 59K mile car in good shape but will need two bolts drilled out where the water pump bolts too. Includes oil pump. ----$20
5. 4.1L Intake manifold, 59K miles on this, no cracks, no water damage, in good shape ready to mod or bolt on. ------$50
6. Heat Sheild for AC Box, in good shape ------$20
7. Remanufactured starter, I have two of these, I may need to keep one but not sure yet. These are both in good working order and dont look to be very old at all. ----$20
8. Windsheil Washer Reseviour Cap, excelent condition, white letters ----$10
9. Adjustable Wastegate Accuator, in great shape, nice and clean, $30
10. Stock Air Filter Canaster Bracket, in good shape, $10
11. AC Line Clips, for olding the AC lines to the core support, includes both of them. $20
12. 86 Grand National Black Pull Strap, excellent condition, only one, -----$30
13. Coil Pack, not sure what this cam off of but it works, has a piece chipped off as you can see in the pics. Would be good if your on a budget or as a spare, working coil pack for cheap. ------$20
14. Oil Pick Up tube, used but in good shape -----$5
15. 36lb injectors, 4 of them, I believe the one missing the cap is bad, I couldnt get a pulse out of it. You may want to check it before you install it, $20 for all 4
16. Chip, for stock Injectors, I dont know whos it is but it was on a car with stock injectors and the car ran very well. -----$10
17. Brass Oil Drain Fitting, adapter for the drain to go into the block, I have two of these. -------$20 each
18. Red Armstrong Chip, for 36lb injectors and 93 gas, car ran very well with this chip. -----$20
19. Oil Drain Back tube, in excellent condition, very clean, very nice, $30
20. Passenger Side black Out quarter glass, in good shape $50
21. Engine Oil Dipstick, has some balck on the top of it as you can see in the pic but overall good shape and usable, ----$15
22. Door Locks, blackout, I dont have the key for them so they'll have to be re-keyed but they are original black actuators. $15 for both.
23. Digital climate Control wiring harness, this is the whole harness including the vaccuum tubes which are not broken, this is in excellent condition. I dont have the controller though. $35
24. Original Radiator Caps, very nice condtion, I have two of these ---$7 each
25. Stock Engine Hoist brackets, I have two maybe three of these, $10 each
26. Black Door Edge Gaurd, good shape! ------$35
27. Steering Column, grey for floor shift, needs a new turn signal stalk and probably a little spray paint, otherwise good! ------$100
28. GN Dash Plaque, nice shape no scratches and such but not much chrome left on it. Overall good shape though! ------$75
My dad also has a bunch of AC Ducting parts for under the dash, if you want any of those just let me know. I dont have pics of that stuff though.
Here you go.
And more
more
5 more pics
This takes forever!!!
Passenger Door Edge Gaurd and dash plaque
I will take these two items. Send me price with shipping to 75094 via PM.
thanks,
Dannyo
turbo and adjustable accutator
I'm interested in turbo and adjustable actuator.As long as the turbos not leaking oil or burning it. I have one of those now. Thanks.
Stock ECM, no chip, no cover, works good! $75
I'll take:
19. Oil Drain Back Tube
25. Stock Engine Hoist Bracket
Just want the plastic timing pointer, would you seperate from T/C?
4. Front Cover, 14 bolt
Next in line for:
26. Black Door Edge Guard, pass side
Thx, -Tim
