Clearing out again......lots of stuff+pics. Some show some cheap
Here are a few more parts:
Stock fuel pressure regulator ----$10
Black out door handles with rods ------$35 set
T Stat hold down bracket ----$10
EGR Valve hold down bracket -----$10
These parts are sold:
Door edge gaurd
Lift bracket #1
Lift bracket #2 (pending)
Engine oil dipstick
36# chip
oil pickup tube
All other parts are still available!
Here's another picture of the digital climate control harness I have. I forgot to picture the black controller box last time.
turbo
Sent ya a pm i'll take turbo and actuator. I also need an oil cooler line if you happen to have one.
Turbo sold!
Dalton, I actually dont have any oil cooler lines, just broke one myself.
These parts are still available:
Show quality very nice stuff:
2. Modded 20 bolt front cover, all Earl Brown mods done and mellings high volume oil pump kit installed. This hasnt been on a motor since it was re-done. Very Very nice. $225
3. Ceramic Coated Uncut Turbo Sheild, extremely nice, hasnt been installed since the coating was done. You wont find nicer than this. $115
4. New ACDelco Lifters, entore set of lifters never used, never opened, $135
Regular Parts (CHEAP):
1. Complete Intercooler Kit (intercooler, shroud, IC fan, both IC brackets), the shroud will need to be re-zip tied cause it a little loose on the bottom but it's in over all good condition. A few paint flakes off the top of the IC. $125
4. Front Cover 14 bolt, came off a 59K mile car in good shape but will need two bolts drilled out where the water pump bolts too. Includes oil pump. ----$20
5. 4.1L Intake manifold, 59K miles on this, no cracks, no water damage, in good shape ready to mod or bolt on. ------$50
6. Heat Sheild for AC Box, in good shape ------$20
7. Remanufactured starter, I have two of these, I may need to keep one but not sure yet. These are both in good working order and dont look to be very old at all. ----$20
8. Windsheil Washer Reseviour Cap, excelent condition, white letters ----$10
10. Stock Air Filter Canaster Bracket, in good shape, $10
11. AC Line Clips, for olding the AC lines to the core support, includes both of them. $20
15. 36lb injectors, 4 of them, I believe the one missing the cap is bad, I couldnt get a pulse out of it. You may want to check it before you install it, $20 for all 4
16. Chip, for stock Injectors, I dont know whos it is but it was on a car with stock injectors and the car ran very well. -----$10
17. Brass Oil Drain Fitting, adapter for the drain to go into the block, I have two of these. -------$20 each
22. Door Locks, blackout, I dont have the key for them so they'll have to be re-keyed but they are original black actuators. $15 for both.
24. Original Radiator Caps, very nice condtion, I have two of these ---$7 each
27. Steering Column, grey for floor shift, needs a new turn signal stalk and probably a little spray paint, otherwise good! ------$100
28. GN Dash Plaque, nice shape no scratches and such but not much chrome left on it. Overall good shape though! ------$75
29. Stock ECM, no chip, no cover, works good! $75
30. Stock fuel pressure regulator ----$10
31. Black out door handles with rods ------$35 set
32. T Stat hold down bracket ----$10
33. EGR Valve hold down bracket -----$10
MAKE RESONABLE OFFERS!!!
