Whooshmobile
- May 26, 2001
I'm getting out of Buicks so I can have more time for my Model A project. So, I may be interested in trades relating to that. All prices are plus shipping.
Eastern Performance CNC heads. Larger 1.77 intake, 1.50 exhaust Fererra valves. Approximately 2000 miles since new. $850
Razor’s alky kit. Nearly new – only ran for ½ tank. $450
RJC powerplate $40
GT6152-S turbo. 4” in, 2.5” out. Precision .63 exhaust housing. It has approximately 1500 miles since new, but was on an engine that developed a rod knock, so it may or may not need a rebuild. It has no thrust play, but there is a bit of radial play. $450
Eastern Performance (ESP) frontmount intercooler. works perfectly, however the 2.5" aluminum pipes are dented where they pass beneath the car. $350
Translator + & 3.5” MAF. Everything works perfectly, however the translator has 1 of the mounting tabs broken off. $275
4” big mouth intake piping. Includes MAF pipe and cold air piping with 4” filter. Adapters to 3.5” MAF included also. $175
3” stainless THDP with dump $400
140mph speedometer. The tach and boost gauges don’t work properly, so they would need swapped from your existing cluster. $60
Chrome up pipe with 2 holes drilled for alky $40
Type II ignition coil and module $60
Let me know if I can answer any questions. I'll probably have more as I sort through things.
chrisrsutton@yahoo.com
RJC powerplate $40
