Code 24...where is vss?
2QWIK4U
Ive never had to replace the vss and would like to know where its at and if any of you guys had the same code 24 and it not be the vss.
i believe the VSS is under the dash near the fuse panel.
D
vss
In dash cluster by speedometer head green in color held by small bolt like 7/32 or 5.5 mm socket to remove
Send me an email and I'll send you a pic of the location. Pretty much the same for all the cars and it's on the back of the speedo.
