The Darkside
Heavy Metal Thunder
- May 25, 2001
I need some help w/ this..... I took a drive in the car last night & went by the local Home Depot. When I came back out & tried to start the car(was only gone 10 minutes or so) it was real hard to start & when it did it ran really rough.. The scan master was acting strange too & showed no data... I unplugged the scan master & plugged it back in & it started working, but I noticed my o2 cross counts were not moving & neither were my integrator #'s. I shut the car down & reset the ECM & car started right up & ran fine back to the house.
Tonight when I got home I started it up & it threw a code 34 immmediately. Car was still idling fine & I let it get up to normal operating temps, but noticed the 02 cross counts were not moving at all. Shut the car own & reset the ECM again & restarted the car. This time car idled fine, the o2 cross counts were cycling quickly & Integrator adjusting normally. My blm's were around 125.
Shut the car down & restarted again...car threw a code 34 again, cross counts not moving, plus I noticed that my IAC #'s were at 0. Usually I see somewhere in the 30+ range, so not sure if that helps to point out my problem??
Any help would be greatly appreciated!!!
The Darkside
The Darkside
