My upgrade
Original instructions at
My GN Page
1985 Grand National "Hot Air" ignition coil upgrade. Here is my experiences with the upgrade. I know as a newbie, I wish there were more step by step instructions such as these, so when I have the opportunity to create one myself, I do. I hope it helps anyone who is trying the upgrade.
My setup is slightly unique because my wiring harness to the CCCI was damaged. I figured, since I need to replace it, go forward with the entire upgrade.
Here are the exact parts that I used and from the vendors I purchased them from. I am in no way affiliated with these companies, I am just a consumer who is trying to be thorough.
ACD# D552 GM# 12353801 -- Coil Packs -- Gyrhead
ACD# D1996 GM# 24503624 -- Ignition Control Module -- Gyrhead
102085 -- 1987 Coil to 1985 Mounting Plate -- Caspers
102087 -- 86-89 CCCI Hotwire Kit -- Caspers
108016 -- CCCI Splice with Crank and Cam Plugs - Special -- Caspers
---------------------- Steps --------------------------
Step 1: Assess the situation. If you are a true newbie, don't be afraid to take pictures even. Here's the current setup with the spark plug wires removed. (Sorry, I didn't have one with them on.)
Step 2: Disconnect Battery. Remove CCCI harness from ignition module. Remove the three bolts holding coil pack setup to the block. Sneak out from radiator hose. Mounting points are highlighted.
Step 3: Remove ignition module from mounting bracket by removing the four nuts on the bottom side. You will not need these nuts anymore. It is not necessary to remove the two larger nuts on the crossbar.
Step 4: Remove the 6 torx screws holding down the coil pack to the ignition module. Save these because you will need them later. Caspers provides an excellent wiring diagram, but I took a picture anyway. (My newbie mistake: I took off the torx screws while still on the vehicle, and I had to reinstall them. Needless extra step. Remove the torx screws on your work bench.) Save the 6 screws because you will need them for the new unit.
Step 5a: Gather the new ignition coil and new module. Place face down.
Step 5b: Note the different heights and quantities on the nuts provided by Caspers.Use the shallow screws for the mounting and save the thick ones for later.
Step 5c: Install the Adapter Plate to the new ignition module.
Step 6a: My coil came with the 6 connectors on the bottom pointing straight out.
Step 6b: Bend with pliers, ever so carefully, into the middle, as close as you can to 90 degrees to the coil pack.
Because of the amount of photos, it's continued in the next thread...
