streetknight
DCVING
- May 26, 2001
Opinions? Performance gains or losses?
SignUp Now!On the street, on a hot day, the cold air will make more power.
But at the track, with proper cool down, there will almost be zero difference.
Also doesn't a cooler intake help assist in reducing detonation?
Well i just made a CAI, and i my car picked up 25-34 HP, but that's just my 2cents. I think the air pickup alot more speed going thru MAF which may not be good, but i made one out of pipe's left over from my Ebay intercooler 3in. Had to get a short Sperco filter from Orieleys, but it flows alot! Looks like K&N.
Octane is the cure for detonation, not cooler air.
But don't take my word for it, go to the track and run back to back test until you are sick and you won't see .1 second or .5 mph difference at the track between the best CAI/Ram Air and a K&N on the MAF.
Cooler air has more oxygen thus resulting in better combustion.
Of course, lean mixtures can lead to detonation which exists when the super-hot compressed fuel/air mixture prematurely explodes, instead of burning with a smooth flame front across the piston dome. Adding more fuel to the mixture can discourage the tendency to detonate.
Another, more effective, method to prevent detonation is to provide cool compressed air to the mixture. Cool compressed air provides the same effect on detonation protection as a rich fuel mixture, and provides an extra margin of engine operational safety.
Octane is the tolerance to higher cylinder psi's
Higher cylinder psi's are the result of power adders (N20, boost,etc), timing and/or higher compression ratio engines (pistons, CC)
